high transmission pressure 3500 6.0l
Old Jun 16, 2014 | 11:29 AM
tonyp1511's Avatar
Default high transmission pressure 3500 6.0l
hi everyone.
im looking at a 2005 chevy 3500 6.0l express cargo van. it has a check engine light on for high transmission pressure. the owner says its never given him an issue. is this something to run away from? or should i spend the money on having a mechanic look at it? thank you all very much. cheers
Old Jun 16, 2014 | 12:18 PM
sledge.impy's Avatar
Are the shifts hard or appear normal?
Old Jun 16, 2014 | 12:21 PM
transmission filter leak/high trans pressure - SaturnFans.com Forums
Re: transmission filter leak/high trans pressure
<hr style="color: rgb(51, 51, 51);" size="1"> You may have to have a pressure test done, the only time I've seen the transaxle oil filter seals blow out and leak was when the pressure regulator spring broke in the valvebody causing the pressure to go high.
Transmission-Problems
Old Jun 16, 2014 | 4:05 PM
tonyp1511's Avatar
i havent driven it yet, its about 2 hours away in New Hampshire. i just dont want to go all the way up there if you guys suggest avoiding it or i will check it out if it may be minor. idk anymore, ive become overwhelmed with shopping for a new van
Old Jun 17, 2014 | 10:23 AM
Sorry, never seen the error on any car I've had.
I suggest you do some more research on transmission line high pressure.
Not sure your chances of finding someone else on here with that same issue.
Might be best to have a dealership examine it.
This could be of course the reason the guy is selling it. Doesn't want it to be his problem.
Old Jun 17, 2014 | 8:11 PM
the trans will enter failsafe if something is slipping...and then raise line pressure. I'd stay away as your probably into a rebuild.
If you can get a price that can cover a rebuild, it may be worth it.
my 06 2500 p/u 4l80E did the same thing and had a broken snap ring land in the 4th clutch housing.
if your in there for a rebuild, there is a tsb to modify the valve body to prevent high line pressure in reverse...make sure it gets done.
in2pro
Dec 25, 2020 11:34 PM
RockinFX
Sep 13, 2015 7:51 PM
otis_xing
Apr 13, 2013 2:31 PM
Nick_Knipp
May 13, 2012 11:31 AM
ep1nephr1ne
Sep 7, 2011 6:19 PM
