How do I fix DTC P1174 - Fuel Trim Cylinder Balance
Old Jul 19, 2024 | 11:00 PM
  #11
Expresscv's Avatar
Wanted to update this a little, do not have the problem solved but did just install the gm brand o2 sensors- not driven it any yet
wont drive this until Sunday but will update if that does anything for p1174
planning to double check downstream o2 sensors and do the ir thermometer on the cats Sunday before I drive it probably , ,maybe this evening
The mechanic I have used on other stuff is going to go it with me Tuesday so hopefully will get more figured out
I will definitely update this as I move forward figuring it out
Old Aug 2, 2024 | 1:01 PM
  #12
Expresscv's Avatar
wanted to update this
put in gm o2 front sensors and think it has solved the p1174..
need to rescan but last I checked it was gone and no other check engine lights
it did not solve my long fuel trim issue, that is about the same...
if the scan pops up an issue later will update this
spot44
Cruze
May 28, 2017 9:20 PM
bell1987
Mar 26, 2013 8:53 AM
firemechanic
Jul 7, 2012 8:48 PM
expressvan00
Jan 13, 2012 1:49 PM
ethanbrogden
Jun 13, 2011 1:01 PM
