Please help me identity this engine
Old Aug 18, 2025 | 1:15 PM
  #11
Triaged's Avatar
You might also look into an OBD2 Bluetooth/WiFi adapter for your phone/ tablet and the Torque Pro app. Not too expensive and at least on my 2015 % ethanol is one of the reported gauges. It tells me a few things... E85 at least where I normally buy it isn't near 85%, more like 50%. It will also let you know how much is in your "normal" gas which could possibly be up to 15%.
Old Aug 19, 2025 | 2:28 AM
  #12
neatchevy's Avatar
Default commands
YEah I am using PYobd. It is a free software along with a pretty good thirty dollar cable. here are the list of commands on there. I do see ethanol on there.
PID Name Description Response Value 00 PIDS_A Supported PIDs [01-20] BitArray 01 STATUS Status since DTCs cleared special 02 FREEZE_DTC DTC that triggered the freeze frame special 03 FUEL_STATUS Fuel System Status (string, string) 04 ENGINE_LOAD Calculated Engine Load Unit.percent 05 COOLANT_TEMP Engine Coolant Temperature Unit.celsius 06 SHORT_FUEL_TRIM_1 Short Term Fuel Trim - Bank 1 Unit.percent 07 LONG_FUEL_TRIM_1 Long Term Fuel Trim - Bank 1 Unit.percent 08 SHORT_FUEL_TRIM_2 Short Term Fuel Trim - Bank 2 Unit.percent 09 LONG_FUEL_TRIM_2 Long Term Fuel Trim - Bank 2 Unit.percent 0A FUEL_PRESSURE Fuel Pressure Unit.kilopascal 0B INTAKE_PRESSURE Intake Manifold Pressure Unit.kilopascal 0C RPM Engine RPM Unit.rpm 0D SPEED Vehicle Speed Unit.kph 0E TIMING_ADVANCE Timing Advance Unit.degree 0F INTAKE_TEMP Intake Air Temp Unit.celsius 10 MAF Air Flow Rate (MAF) Unit.grams_per_second 11 THROTTLE_POS Throttle Position Unit.percent 12 AIR_STATUS Secondary Air Status string 13 O2_SENSORS O2 Sensors Present special 14 O2_B1S1 O2: Bank 1 - Sensor 1 Voltage Unit.volt 15 O2_B1S2 O2: Bank 1 - Sensor 2 Voltage Unit.volt 16 O2_B1S3 O2: Bank 1 - Sensor 3 Voltage Unit.volt 17 O2_B1S4 O2: Bank 1 - Sensor 4 Voltage Unit.volt 18 O2_B2S1 O2: Bank 2 - Sensor 1 Voltage Unit.volt 19 O2_B2S2 O2: Bank 2 - Sensor 2 Voltage Unit.volt 1A O2_B2S3 O2: Bank 2 - Sensor 3 Voltage Unit.volt 1B O2_B2S4 O2: Bank 2 - Sensor 4 Voltage Unit.volt 1C OBD_COMPLIANCE OBD Standards Compliance string 1D O2_SENSORS_ALT O2 Sensors Present (alternate) special 1E AUX_INPUT_STATUS Auxiliary input status (power take off) boolean 1F RUN_TIME Engine Run Time Unit.second 20 PIDS_B Supported PIDs [21-40] BitArray 21 DISTANCE_W_MIL Distance Traveled with MIL on Unit.kilometer 22 FUEL_RAIL_PRESSURE_VAC Fuel Rail Pressure (relative to vacuum) Unit.kilopascal 23 FUEL_RAIL_PRESSURE_DIRECT Fuel Rail Pressure (direct inject) Unit.kilopascal 24 O2_S1_WR_VOLTAGE 02 Sensor 1 WR Lambda Voltage Unit.volt 25 O2_S2_WR_VOLTAGE 02 Sensor 2 WR Lambda Voltage Unit.volt 26 O2_S3_WR_VOLTAGE 02 Sensor 3 WR Lambda Voltage Unit.volt 27 O2_S4_WR_VOLTAGE 02 Sensor 4 WR Lambda Voltage Unit.volt 28 O2_S5_WR_VOLTAGE 02 Sensor 5 WR Lambda Voltage Unit.volt 29 O2_S6_WR_VOLTAGE 02 Sensor 6 WR Lambda Voltage Unit.volt 2A O2_S7_WR_VOLTAGE 02 Sensor 7 WR Lambda Voltage Unit.volt 2B O2_S8_WR_VOLTAGE 02 Sensor 8 WR Lambda Voltage Unit.volt 2C COMMANDED_EGR Commanded EGR Unit.percent 2D EGR_ERROR EGR Error Unit.percent 2E EVAPORATIVE_PURGE Commanded Evaporative Purge Unit.percent 2F FUEL_LEVEL Fuel Level Input Unit.percent 30 WARMUPS_SINCE_DTC_CLEAR Number of warm-ups since codes cleared Unit.count 31 DISTANCE_SINCE_DTC_CLEAR Distance traveled since codes cleared Unit.kilometer 32 EVAP_VAPOR_PRESSURE Evaporative system vapor pressure Unit.pascal 33 BAROMETRIC_PRESSURE Barometric Pressure Unit.kilopascal 34 O2_S1_WR_CURRENT 02 Sensor 1 WR Lambda Current Unit.milliampere 35 O2_S2_WR_CURRENT 02 Sensor 2 WR Lambda Current Unit.milliampere 36 O2_S3_WR_CURRENT 02 Sensor 3 WR Lambda Current Unit.milliampere 37 O2_S4_WR_CURRENT 02 Sensor 4 WR Lambda Current Unit.milliampere 38 O2_S5_WR_CURRENT 02 Sensor 5 WR Lambda Current Unit.milliampere 39 O2_S6_WR_CURRENT 02 Sensor 6 WR Lambda Current Unit.milliampere 3A O2_S7_WR_CURRENT 02 Sensor 7 WR Lambda Current Unit.milliampere 3B O2_S8_WR_CURRENT 02 Sensor 8 WR Lambda Current Unit.milliampere 3C CATALYST_TEMP_B1S1 Catalyst Temperature: Bank 1 - Sensor 1 Unit.celsius 3D CATALYST_TEMP_B2S1 Catalyst Temperature: Bank 2 - Sensor 1 Unit.celsius 3E CATALYST_TEMP_B1S2 Catalyst Temperature: Bank 1 - Sensor 2 Unit.celsius 3F CATALYST_TEMP_B2S2 Catalyst Temperature: Bank 2 - Sensor 2 Unit.celsius 40 PIDS_C Supported PIDs [41-60] BitArray 41 STATUS_DRIVE_CYCLE Monitor status this drive cycle special 42 CONTROL_MODULE_VOLTAGE Control module voltage Unit.volt 43 ABSOLUTE_LOAD Absolute load value Unit.percent 44 COMMANDED_EQUIV_RATIO Commanded equivalence ratio Unit.ratio 45 RELATIVE_THROTTLE_POS Relative throttle position Unit.percent 46 AMBIANT_AIR_TEMP Ambient air temperature Unit.celsius 47 THROTTLE_POS_B Absolute throttle position B Unit.percent 48 THROTTLE_POS_C Absolute throttle position C Unit.percent 49 ACCELERATOR_POS_D Accelerator pedal position D Unit.percent 4A ACCELERATOR_POS_E Accelerator pedal position E Unit.percent 4B ACCELERATOR_POS_F Accelerator pedal position F Unit.percent 4C THROTTLE_ACTUATOR Commanded throttle actuator Unit.percent 4D RUN_TIME_MIL Time run with MIL on Unit.minute 4E TIME_SINCE_DTC_CLEARED Time since trouble codes cleared Unit.minute 4F unsupported unsupported
50 MAX_MAF Maximum value for mass air flow sensor Unit.grams_per_second 51 FUEL_TYPE Fuel Type string 52 ETHANOL_PERCENT Ethanol Fuel Percent Unit.percent 53 EVAP_VAPOR_PRESSURE_ABS Absolute Evap system Vapor Pressure Unit.kilopascal 54 EVAP_VAPOR_PRESSURE_ALT Evap system vapor pressure Unit.pascal 55 SHORT_O2_TRIM_B1 Short term secondary O2 trim - Bank 1 Unit.percent 56 LONG_O2_TRIM_B1 Long term secondary O2 trim - Bank 1 Unit.percent 57 SHORT_O2_TRIM_B2 Short term secondary O2 trim - Bank 2 Unit.percent 58 LONG_O2_TRIM_B2 Long term secondary O2 trim - Bank 2 Unit.percent 59 FUEL_RAIL_PRESSURE_ABS Fuel rail pressure (absolute) Unit.kilopascal 5A RELATIVE_ACCEL_POS Relative accelerator pedal position Unit.percent 5B HYBRID_BATTERY_REMAINING Hybrid battery pack remaining life Unit.percent 5C OIL_TEMP Engine oil temperature Unit.celsius 5D FUEL_INJECT_TIMING Fuel injection timing Unit.degree 5E FUEL_RATE Engine fuel rate Unit.liters_per_hour 5F unsupported unsupported
Bullitt39
Nov 13, 2021 10:05 PM
dtorres
Feb 18, 2021 5:25 PM
dtorres
Feb 16, 2021 10:41 PM
ray caldwell
Nov 21, 2020 11:22 PM
Ethan Gueck
Jul 4, 2017 6:45 PM
