Power Window problem. Doesn't work with circuit breaker, fuse OK!
Old Jul 30, 2025 | 2:29 PM
SuperRA's Avatar
Default Power Window problem. Doesn't work with circuit breaker, fuse OK!
Hi everyone. I got an Express 3500 recently and have started to have problems with my power windows not working. I traced it down to the 25A Circuit Breaker in the fuse box under the driver's seat. Even though the CB continuity tested ok, I temporarily sent power with a power probe and the windows worked. Replaced the CB and the windows did not work. (New CB continuity tests ok) I then put in a 25A fuse and the windows work. (so far, its only been a few hours.)
I was wondering if anyone else had the same or similar issue or any ideas why a circuit breaker would not work, but a fuse would?
Thanks!
Old Jul 30, 2025 | 10:15 PM
Robby17's Avatar
Could be a weak or slow-trip breaker not handling the initial motor surge fuses react faster. If the fuse holds, just run it. Common issue in these vans.
Old Jul 31, 2025 | 6:37 PM
SuperRA's Avatar
Hi Robby, thanks for the reply. For kicks and giggles I put the CBs (both new and old) back in and the windows now continued to work! I guess I'll just carry around the fuse as a backup.
jamesm113
Jun 4, 2024 4:49 PM
armonica
Jul 30, 2021 4:17 AM
saimer
Jun 26, 2019 5:24 PM
easymacdonald
Jul 27, 2016 12:41 PM
kingfish62
Aug 9, 2010 3:52 AM
