Removal / Installation instructions for RIGHT Front Shock for 2001 Chevy Express 1500
Looking for a little help with the removal and installation of a RIGHT Front Shock on my 2001 Chevy Express 1500. I've removed the wheel, removed the plastic wheel well / engine cover. I am unable to get any useful tools onto the top of the shock to remove the bolt as there is so little room to work with. The shock spins when I am able to get a small hand wrench on the bolt. But with so little space to work with, I am not able at the same time to secure the top square end of the shock itself so it doesn't turn while removing the nut.
There must be a trick to this install and I'm hopeful someone here has already discovered it!
Thanks in advance!!!
Appreciate the feedback. However, it is my experience these past few days that there is not enough room to get your 2 hands, a set of vice grips and a open/closed end wrench into that small cavity, and then make the motions necessary to hold either the top of the shock in place and currently loosen the shock bolt, or vice versa.
I was hopeful someone had a suggestion on how to deal with this specific situation on this specific make and model.
Hello again, I have a 2008 Express 1500, last summer I replaced the shocks. Here is a picture of mine, click on it to change to vertical view, I think. Pretty sure the suspensions are the same. Is your situation different? Just checked the view does not change to verical, sorry. OK it will change if you click on the URL.
https://chevroletforum.com/forum/att...1&d=1489674021
So what you have is not like this? Click on URL below to rotate the picture. Can you take a picture, maybe we could help with that?
https://chevroletforum.com/forum/att...1&d=1489683118
