Replaced lower manifold gaskets, now van won't start
Hello
Any ideas anybody?
Ive replaced the lower manifold gaskets in my 2000 5.7 van, now it wont start!
Ive spent days making sure the timing is set right, making sure ive got TDC and then lining up the pointer to the number 8 inside the cap...(have even just mathodicly turned the distributor a tooth at a time all the way around to make sure i wasn't doing something wrong)
But set at the correct timing settings it just spins over like it wants to start but doesn't quite get there.
The van run great before i worked on it.
Also ive checked the fuel pump is giving the right starting psi readings. and have checked to see if it needs a 'passlock relearn' to the security system, but that checks out ok.
Ive read on here that a lot of people have the same problem after doing a manifold gasket job..but no solutions posted
Thanks for any help
Any ideas anybody?
Thanks for any help
Have spent another day on this
From what i can find the timing is good
the fuel pressure is good
the vehicle is trying to start
but when i remove the plugs they're bone dry
would indicate something is stoping the fuel at the fuel injection?
Any Ideas?
Any Ideas?
put your finger on the relay when you turn the ignition switch. do you feel it close? you can also put a test light in there to check the PCM is energizing the circuit.
if the relay isnt clicking when you touch it, try replacing it with another(usually the AC relay). if it is closing then press the shrader valve and see if you are getting fuel at the rail. or at least getting fuel pressure.
Update
got the van started!
Found that the spark plugs were faulty
probably due to the fact the manifold gaskets had failed and water was getting in to the cylinders. Then leaving the van standing for a few weeks before i relaced the gaskets allowed the plugs to rust slightly
Thanks for the help
Thanks for the help
lookingformore
Jun 1, 2012 8:55 AM
2000malibu
Jan 6, 2008 4:21 PM
