Stuck Wheels :|
Old Sep 10, 2019 | 10:18 PM
Kael's Avatar
Default Stuck Wheels :|
Howdy all, guess I'll start without pictures.
New owner of an old 2005 Express 2500 with plenty of miles. Didn't pay that much and it will be a project, though intend to keep it a work vehicle.
Of course, I've hit stopper #1: Rusty Wheel removal. Got one out of four so far and, luckily, all lugs nuts off. The one front, I haven't tried many tricks yet. The big problem is the two rear.
I've tried:
Penetrating fluid for days
Whack-a-tire
Drive around the block several times with loose nuts
Dropping with a 2x4 on the inner underside of the tire
Driving back and forth of same 2x4
Propane torch
No luck, not even a blip. I'm lost what else to try, any other tidbits? Am I missing something?
Old Sep 10, 2019 | 10:34 PM
can you get a jack or something between the wheel and the frame? A great big long 2x4 to lever it off?
Old Sep 11, 2019 | 7:47 AM
Kael's Avatar
Might try a jack, what's the likelihood of bending the rim?
Old Sep 11, 2019 | 12:22 PM
m2akita's Avatar
Do you have an air hammer (
https://www.amazon.com/s?k=air+hammer&ref=nb_sb_noss_1 https://www.amazon.com/s?k=air+hammer&ref=nb_sb_noss_1
)? Try hitting the wheel with that. might be able to vibrate the rust loose.
Old Sep 11, 2019 | 1:57 PM
Kael's Avatar
Good idea, air hammer, next try.
So far, after much cursing, no progress. These things are STUCK. About ready to head to a shop just to remove wheels!
Tried jack, no good place to push without the the steering rack taking a trip. Whacking from inside, zippo. Torch, heated some before the propane bottle gave its last gasp. And last, couldn't find a decent leverage point for my crow bar!
I already shudder how bad removing the brake calipers will be. Oh well, gives me something to do.
Old Sep 12, 2019 | 8:35 AM
Kael's Avatar
I tried a palm nailer with a piece of rebar. Cost me some paint and took about four whacks from the hammer afterward and finally popped!
Two more to go...yeah, maybe this weekend.
Old Sep 13, 2019 | 2:18 PM
Kael's Avatar
POP! POP! POP! WHINE!
Got one of rear wheels off, finally. Hydraulic jack pushing off the frame. Had to do one end, rotate 180, do the other. Thing was stuck on the hub center. Trying to stop that rust weld will be interesting.
One to go!
Old Sep 13, 2019 | 4:37 PM
SteveROntario's Avatar
Keep a bottle of copper anti-seize around for when you put the wheels and rotors back on. I wouldn't be surprised if your wheel bearings give out in a few months. They don't like forceful removal of wheels and brake rotors.
emb505
Aug 26, 2016 9:45 PM
scarl19
Jan 4, 2014 11:21 PM
mRambo
Nov 27, 2013 12:45 AM
Derek2023
Jul 17, 2007 12:04 AM
new_york_system
Apr 21, 2007 12:48 PM
