tach
Old Jul 18, 2013 | 6:49 PM
edac's Avatar
Default tach
Did the 99 express have a tach as a factory installed option?
Old Jul 20, 2013 | 4:43 PM
canucklehead's Avatar
I have an 02 and it did not. Van have not had tachs for ages....unless the new ones do....
I installed a 2" aftermarket one in the dash.
Old Jul 20, 2013 | 7:52 PM
greenfire's Avatar
No Tach here.
Old Jul 21, 2013 | 11:22 AM
edac's Avatar
Well the way it looks, I spun rod bearings and seized my engine. Put in a new long block to find out I have trans problems. Van is so quiet that I want a tach so I can keep an eye on the RPM's. Was hoping to change the cluster to one with a tach, but I haven't seen one. That's why I asked. Where did you install your tach? Do you like where it's at? What would you have done differently?
Old Jul 21, 2013 | 12:59 PM
The wire harness that goes into the coil has 2 wires, but the connector can hold 3. Pull the connector and the plug that seals that middle hole and there is your lead for the tach.
I put mine in my dash on the square piece bewtween the steering column an the stereo.
It is small, but I managed to get a cheap 2" one for there.
It works fine, and I did not want it above the dash. My regret was not trying to get a 2 1/4 one as that size is more common. My tach is cheap and I have to replace it under warrenty often.
There is an aluminum strut behind there so don't get a super deep one....or it will angle the tach towards the passenger side......
Old Jul 21, 2013 | 5:02 PM
edac's Avatar
I was thinking of the 2" model and put it in the same place, but after your comment maybe I'll try to squeeze a larger one in there.
Old Jul 22, 2013 | 1:05 AM
The problem is that if you want the tach to centre on that plastic square piece then the strut behind will come into play....but if you make up a plate to go over the dash and cover that pice then you can move the tach over toward the steering column and maybne angle it up a bit.....then you can go bigger.
Old Apr 14, 2020 | 3:29 PM
woodhooks's Avatar
where is the coil? Thanks.
mmonkey81
Aug 6, 2009 1:30 PM
brautig
Dec 12, 2006 8:01 PM
Destructo
Nov 7, 2006 8:04 AM
joes91
Mar 29, 2005 12:36 PM
