1995 silverado won't start
Old Mar 22, 2012 | 11:40 AM
chevymaniac21's Avatar
Default 1995 silverado won't start
Hi I have a 1995 Chevy Silverado 1500 mark III step-side, 2WD with a 305 engine and 5 speed tranny in it. Yesterday I was pulling out of a parking lot when all of the sudden it just died on me so I tried starting it and the engine would turn over but wouldn't start so I thought the fuel pump might of went out so I turned the key to the on position to see if I could hear the pump but I didn't hear it turn on or anything but then I noticed that whenever I turned the key on none of the gauges moved or the seat belt, abs and brake lights turned on so I checked all the fuses and relays and made sure the grounds didn't come off but everything was ok. And whenever I hauled it home I tested the fuel pump leads to see if they had current but it read 0v. And I checked all the wiring to make sure no rodents chewed on it but it all looked good. What could be the cause of this?
Old Mar 22, 2012 | 12:24 PM
Gundog's Avatar
If your guages are not coming on it sounds electrical. I woild check your battery, make sure your battery cables are tight, then check the power wire going from the starter to your ignition switch.
Old Mar 22, 2012 | 2:12 PM
The engine turns over so it can't be the battery and I checked all the cables and they're all tight.
Old Mar 23, 2012 | 12:52 PM
Gundog's Avatar
Pull a plug, ground it and see if you are getting a spark.
Old Mar 23, 2012 | 6:19 PM
RacerX's Avatar
Check your PCM harness. It may have become disconnected. Instrument cluster is powered through the PCM as well as the fuel pump. As well as spark. I dont think you are going to have spark either.
Old Mar 24, 2012 | 10:58 AM
I asked a friend about it and he said that he's sure it's the ignition switch. He said it's common for the ignition switch to fail because he's fixed a whole lot of chevy trucks and most of them had that problem. I ordered one and whenever it gets here I'll update on here and see if it solved the problem. Thanks everyone for the help, I really appreciate it
Old Mar 24, 2012 | 5:40 PM
RacerX's Avatar
yea I was thinking that last night too, but I didnt know why it would crank though if the switch was bad but it is possible.
Old Apr 14, 2012 | 9:53 PM
BADBOWTIE94's Avatar
Hi, I am having the same problem, if i let my truck sit for a few hours it will start right up is the only difference from your problem. when it does start, in about 10 minutes it will die again if not right away. I just replaced my ignition switch and it still died in about 1o minutes.
Old Apr 14, 2012 | 11:12 PM
cleveland63b's Avatar
what have you checked? fuel pressure good?
Old Apr 14, 2015 | 8:58 PM
chevydrifter's Avatar
New User
Awaiting E-mail Confirmation
Hi i have a 95 chevy mark III stepside 305 5 speed and today i took it for a spin and it suddenly stopped and it wouldnt start again so i got my other pickup and pulled it and it started but didnt have power and with flames coming out the exhaust so i shut it of to see if it would start on its own and it didnt start up again and i have no idea whats wrong with it
Tahoetrucken
Oct 14, 2015 12:28 PM
RickSpringfield
Aug 16, 2013 11:23 AM
Bob5150
Aug 21, 2010 8:12 AM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
