1999 Silverado Help Question - Brakes, what is up ....help, advice needed please!
I bought a 1999 Chevy Silverado 4x4, a little body rust, and in decent shape. Runs really good. Bought it mostly for winter driving. Started having brake troubles. Had all of the brakes, rotors, pads, lines were bled, new brake fluid put in, new brake replaced, line put on to the tune of $1000. Truck ran great, stopped good until last week where the brake pedal went to the floor. The truck stopped. This problem is intermittent, seems to happen at random. I can pump the brake and the truck still stops. Went to another brake specialist and said it is probably the hydro vac, or could be bad brake fluid in the brake cylinder, or just a bad brake cylinder. Looking at more big money here again. Truck stops ok after one tap on the brake. Can someone...anyone tell me what is going on with this and what I can expect? Should not a pressure bleed for $100 have been done already? Air in cylinder? Any advice or ideas would be helpful. Great truck, restoring the body too but not until I get this brake situation resolved. Thanks!
