2005 chevy impala wont start keeps on cranking over
Old Apr 13, 2012 | 8:23 PM
I'm lost's Avatar
Default 2005 chevy impala wont start keeps on cranking over
I need help it keeps on cranking over if I hit the gas it will start but bogs out
Old Apr 13, 2012 | 9:14 PM
cleveland63b's Avatar
by hit the gas do you mean having the pedal to the floor? if thats the case you may have flooded it and it tries to start in clear flood mode
otherwise you'll have to start with the basics, fuel pressure spark and compression
Old Apr 13, 2012 | 9:18 PM
Are you saying that it is hard to start or won't start at all?
Old Apr 14, 2012 | 7:26 PM
I'm lost's Avatar
I must of flooded it now it will not start but when I held the pedal down it did start but felt like it was miss firing and it has no check engin light on
Old Apr 14, 2012 | 10:43 PM
probably flooded, holding the pedal down puts it in "clear flood" mode
Old Apr 15, 2012 | 9:58 AM
I'm lost's Avatar
How do I clear flood mode sry I'm a noob to chevys
Old Apr 15, 2012 | 9:48 PM
you already did, when you hold the accelerator to the floor and crank it does automatically
if its running fine now then I wouldn't worry about it
Old Apr 15, 2012 | 11:16 PM
John from Canada's Avatar
Clean the idle air control valve.
Old Dec 2, 2012 | 11:15 PM
Ultiem Crystal's Avatar
Default Crank no start
I have a similar issue, only car was running fine 5 minutes before the no start occurred.
symptoms are crank no start, with no gauges i confirmed pressure to the fuel rail so fuel delivery is good. I have yet to test spark and air
Battery is ok so is starter and alternator.
but the 2 solenoids by the throttle body kept turning on randomly. My first guess is the idle control solenoid might be malfunctioning but i dunno if that causes a no start.
Any ideas?
Old Dec 6, 2012 | 6:45 PM
just because theres fuel at the rail doesnt mean its the right pressure
thisnthat
Nov 20, 2012 11:36 AM
missy82tx
Jun 29, 2011 2:30 PM
rgnbull1227
Feb 5, 2010 2:24 PM
country_09
Oct 16, 2009 5:41 PM
