2005 Chevy Silverado transmision
Old May 21, 2013 | 10:18 AM
huskersrule1995's Avatar
Default 2005 Chevy Silverado transmision
Truck does not want to shift out of first gear till I get above 3500 Rpm, then it stays in second for a couple of seconds and then shifts into 3rd gear. Makes no noise and runs fine at all speeds and gears except from first to second. Any ideas where I need to look first, or do I just get ready to put another transmision in?
Old May 21, 2013 | 11:09 AM
or can we continue driving it with out hurting anything else
Old May 21, 2013 | 11:12 AM
SWHouston's Avatar
I'd run a good cleaner in it, before I started thinking about major repair.
Any Codes ?
You have the Tow Package ?
Old May 21, 2013 | 11:52 AM
no codes, and it has the tow package
Old May 21, 2013 | 12:11 PM
SWHouston's Avatar
Ok, but I'm still in favor of the cleaner first...
When you put it in Tow Mode, the shift points and firmness are changed to some degree, but does that effect the problem, or does it continue in Tow Mode as well ?
Old May 23, 2013 | 8:07 PM
I checked again. No tow/haul working. And no second gear at all
Old May 23, 2013 | 11:01 PM
SWHouston's Avatar
Umm, what you're saying is that the problem has worsened !?
Wouldn't an overhaul be cheaper than another Tranny ?
Old May 25, 2013 | 11:25 AM
I guess it had, This is my sons truck, and he did not mention that the tow/haul did not work. When you are in third gear about 40 mph and you step down one it just down shift and does not do anything but ref up. You let back off the gas it shifts into 3rd and everything is good. I have not a chance to get it to a dealer to have them check it. I was just hoping I would have a good place to start before taking it to them.
Old May 25, 2013 | 1:48 PM
SWHouston's Avatar
Ok, I understand now, then...
definitely run a good cleaner through it first, that just may clear up the problem. An inexpensive "test" to see if it needs more.
bigfish88
Apr 2, 2014 11:22 AM
mattwehrwein
Mar 30, 2013 6:06 PM
wgasca
Nov 25, 2009 12:11 PM
typhoon4x4
Sep 29, 2009 10:13 PM
indyartist
Apr 25, 2009 8:08 PM
