283 wont start HELP!!!
Old May 5, 2010 | 5:46 PM
gates62's Avatar
Default 283 wont start HELP!!!
I got 62 chevy c10 with a 283. started fine the other day and now nothing! no power to anything lights stereo nada. she does start when i put screw driver to starter and when i turn on lights she dies. Any ideas?
Old May 5, 2010 | 6:44 PM
maxxman04's Avatar
fuses, ignition switch, cable connections
Old May 5, 2010 | 8:10 PM
Terry Neff's Avatar
Check the voltage at the battery while it is not running.Than again while it is running.The difference is the charging system.It's the charging system that I think isn't working so the engine is running totally off the battery and killing it.
Let us know what you have found.
Stereo???.Is that a new addition??.
Old May 5, 2010 | 11:15 PM
gates62's Avatar
stereo is a new addition.
Old May 5, 2010 | 11:16 PM
gates62's Avatar
fuses are good and ignition switch is good not sure on cables
Old May 6, 2010 | 3:57 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Sounds like the source of the problem would be in the positive connection between the battery and the fuse center.
Old May 6, 2010 | 10:13 AM
therewolf's Avatar
Higates62,
Welcome to the Chevy Forums.
Ignore this if you've already done it, but replace your battery cables. The battery cables can cause you a world of grief.
They tend to corrode from the inside, under the insulation. Don't forget the engine-to-firewall ground strap.
As your wires corrode, your battery CCAs wind up going to heating up corrosion in your wires, instead of going to your starter.
Old May 10, 2010 | 3:45 PM
gates62's Avatar
replaced both battery cables! still not run the starter clicked over a few times but not enough to turn over engine.
Old May 11, 2010 | 1:20 PM
gates62's Avatar
battery was dead she wants to start now but she dont seem like its getting spark going to check coil thanx for all the help!
sleepingciv
Jul 25, 2020 1:03 PM
cukali
Jul 16, 2011 7:14 PM
badintentionz
Dec 17, 2006 4:12 AM
