2wd conversion to 4wd
Old May 21, 2010 | 10:44 AM
Texcowboy's Avatar
Default 2wd conversion to 4wd
Want to kno if any one has ever switched there chevy to 4wd. I have a 92 chevy with 87000 miles I love the truck in awesome shape I need 4wd. I don't want to buy diff truck. This one is my baby taken it through some serious stuff and it's made it through. Is there any place on line I can buy a conversion kit axles suspension the works. Thanks for help
Old May 21, 2010 | 10:47 AM
gotstylez's Avatar
if your going to go to 4x4..i'd do a solid axel swap. the IFS sucks! not sure where u can order a kit tho..might have to google it..im running a lil late for work.
Old May 22, 2010 | 1:26 PM
Texcowboy's Avatar
I'm thinking get a 2500 that is wrecked either rollover ir side collision so nothing underneath is damaged
Old May 22, 2010 | 5:49 PM
gotstylez's Avatar
well if its a daily driver that will work good..but if its a mudder IFS sucks in the mud lol
Old May 23, 2010 | 7:38 AM
Texcowboy's Avatar
It will be a farm truck. It will also be driven on road
Old May 23, 2010 | 8:39 AM
gotstylez's Avatar
that will work then only thing u need to make sure it has is the front gears and rear gears to be the same or you will destroy your transfercase
Old May 24, 2010 | 8:55 AM
Texcowboy's Avatar
will every thing bolt directly up or will i have to wed cut and drill the works.
Old May 24, 2010 | 3:10 PM
gotstylez's Avatar
probably be some work to it..... since your going from 2wd to 4x4
Old May 24, 2010 | 10:41 PM
therewolf's Avatar
Hi Texcowboy,
Welcome to the Chevy Forums.
I agree with gotsylez, if you're going to go through the trouble to do the 4WD conversion, you may as well get rid of the IFS and put a solid axle up front, too. IFS is a real dog offroad.
Just because it's a 2500 doesn't mean it doesn't have IFS. Do a thread search in the truck sections, a lot of 4WD and solid axle conversion info is there.
Old Jun 8, 2010 | 6:55 AM
Texcowboy's Avatar
Will do. What would be best buy Dana 40 axle and cut It so it fits or buy one pre fitted
