back firing
Old Jan 27, 2011 | 5:34 PM
94chevyarmyguy's Avatar
Default back firing
Hello all, I have a 1994 chevy 5.7L 4x4. First thing in the morning the truck will barely run and even backfires when going down the road; idles real rough. Towards the end of the day it will do the same thing but not as bad sometimes it will run like nothing is wrong. Help please!
Old Jan 28, 2011 | 10:47 PM
2wd-K5's Avatar
usually an exhaust leak will make it backfire, as for the rough running if the exhaust doesnt solve it, try a tune-up if you havent done one lately
Old Jan 29, 2011 | 8:55 PM
It had a Header leak, fixed that today and also put plugs, Distributor cap, and rotor but it still run's like crap.
Old Jan 30, 2011 | 4:31 PM
2wd-K5's Avatar
well, i have 2 more thoughts if the check engine light isnt on, EGR valve, or head gasket take a compression test to find out if it is a head gasket
Old Jan 30, 2011 | 8:23 PM
RacerX's Avatar
Check the vacuum hose running from the TBI to the MAP sensor and replace it if ANY of it comes off in your hands.
Old Feb 1, 2011 | 8:45 PM
Replaced the EGR Valve today, fixed the problem. Thanks for everyone's help.
Old Feb 5, 2011 | 12:08 AM
2wd-K5's Avatar
awesome
Old Feb 5, 2011 | 2:48 PM
RacerX's Avatar
Yea I can see this. The pintle on the EGR was stuck between open and shut. At idle it would run rough because it was open. And at mid throttle it would sound like it backfiring when it was actually detonating because the vacuum on the EGR draw isnt open wide enough.
liftedmaroonchevy
Apr 7, 2012 1:15 AM
grem62483
Nov 29, 2007 12:02 PM
crewchief888
Oct 12, 2007 6:59 PM
Ryan Markt
Jan 28, 2007 9:39 PM
UnRumble
Dec 20, 2006 8:57 PM
