Bad Switch?
Old Mar 4, 2009 | 8:45 AM
dcoperator's Avatar
Default Bad Switch?
I've got a 1997 Lumina Sedan with nearly 120,000 mis. on it and the heating ducts are stuck on window defrost. I can't change the air flow to the floor or vents...would this problem be in switch itself? By the way the rear defrost portion of the switch does work..Any thoughts?
Old Mar 4, 2009 | 2:12 PM
shawnvw's Avatar
Banned
check for broken vacuum lines under the hood. The switch is controlled by vacuum. A loss of vacuum makes the system default to defrost for safety
Old Mar 4, 2009 | 6:13 PM
dcoperator's Avatar
Wouldn't that make the car run like sh@#@$%?
Old Mar 8, 2009 | 6:44 PM
dcoperator's Avatar
Thanks SHAWNVW for the amazing diagnosis! After an indepth search under the hood, I discovered the vacuum line running through the firewall was separated at a union. Hooked it back together and everything works great now!! Great job SHAWNVW!
Chev_Hoe
Jan 14, 2014 9:41 PM
loced27
Apr 17, 2013 1:50 AM
bavant
Jan 16, 2012 2:12 PM
LatitudeDancer
Jun 3, 2011 1:06 PM
chevymalibu01
Mar 2, 2010 1:38 AM
