Blower Motor stopped working
Old Jul 30, 2024 | 5:57 AM
  #11
Gumby22's Avatar
Originally Posted by Ellerocks
I don't have a voltage tester . however eventually it finally started, but the speed kept changing. So I am going to change the resister
Try tapping on the blower motor with the handle of a screwdriver (preferably rubber or wood) - if the speed stabilizes while tapping and/or remains stable until the motor is shut off and restarted, the motor has corrosion build up internally. A new resistor won’t fix it.
It’s generally recommended to replace the resistor and blower motor at the same time. Considering the amount of water you state has been inside the HVAC box/blower, I highly recommend you replace both, regardless of how new either one may be.
Old Jul 30, 2024 | 2:36 PM
  #12
Ellerocks's Avatar
ok, thanks, hope i can send this one back then, Ive only had it less than a week, and I can't afford another one.
Old Jul 30, 2024 | 3:56 PM
  #13
Gumby22's Avatar
You can try cleaning the motor with electronic contact cleaner and compressed air - just keep in mind the corrosion has already started to form and will continue to form, eventually causing motor to fail.
Do not let the motor “free wheel” as you’re spraying it with air - apply light pressure with one or 2 fingers on the wheel edge as a drag to prevent it from spinning too fast.
Old Jul 30, 2024 | 11:33 PM
  #14
Ellerocks's Avatar
ok thanks i will do that tomorrow..
Dave DC
Aug 24, 2021 9:55 PM
RedondaBay
Jan 6, 2015 10:34 PM
Goat-v
Jun 2, 2014 4:28 PM
gofer
Oct 20, 2009 7:53 PM
