Cam
Old May 28, 2009 | 9:23 PM
  #11
Mike Sigmond's Avatar
ROTM Coordinator
Ahhh, I just have the procedures to remove and reinstall it, no specs. Shawn might know for sure. sorry
Originally Posted by suzuki-guy
Mmk thanks!! My gauge only goes to like 10
Is that the fuel guage you just got , or do you have a vacuum guage? Thier 2 different things.
Old May 28, 2009 | 9:29 PM
  #12
suzuki-guy's Avatar
Yes I know(fuel pressure blows vacuum sucks!) I got A vaccuum gauge!!
Old May 28, 2009 | 9:32 PM
  #13
ROTM Coordinator
Sorry , I should have realized you knew that.
Old May 28, 2009 | 11:10 PM
  #14
suzuki-guy's Avatar
It has a hunting idle. Runs fine idles fine but when you are going through a parking lot or coming to a stop the RPMS go down to 500 then above 1000 then settles at 850. I have replaced every sensor trust me. Good compression, redid top end(heads, valves,rockers, pushrods) No codes.Thanks
Old May 28, 2009 | 11:20 PM
  #15
suzuki-guy's Avatar
MMk thanks Gary!!
Oh Sorry Mike I didn't mean to sound sarcastic!
Old May 29, 2009 | 1:50 AM
  #16
ROTM Coordinator
Sounds like she has the hicups Computers can go bad but they usually just stop completely or get a CE light, unless its a burnt resistor in one of the signal lines in the input of the computer. Id think it would be a loose wire, bad part, vacuum(which you have a thread about) before the ECM goes bad.
Old May 29, 2009 | 2:40 AM
  #17
suzuki-guy's Avatar
Yeah I took it off and cleaned it and checked it with a vacuum tester. Could there be carbon inside my intake where the EGR Sits?
Old May 29, 2009 | 2:41 AM
  #18
suzuki-guy's Avatar
Thats what I htought but at this point I ecpect anything! Lol
Old May 29, 2009 | 2:52 AM
  #19
suzuki-guy's Avatar
Default Egr valve
Can An EGR valve on a 1995 5.7 litre 350 be tested with a hand vacuum pump? I tested it and when vacuum was applied it bogged down(Normal) But my question is can it still be bad? On autozones website it said this EGR valve can not be tested with a vacum pump. Thanks guys
Old May 29, 2009 | 3:45 AM
  #20
ROTM Coordinator
Yea..
