Cam
Old Jun 17, 2009 | 8:39 PM
  #71
suzuki-guy's Avatar
Yes it is rocks a little but not much
Old Jun 17, 2009 | 9:32 PM
  #72
MDTAHOE's Avatar
Professional Mechanic
Well it is pretty safe to say it is not timing (valve or ignition) and it is not too lean. Also probably not internal engine issue (cam), the gauge would bounce. How about the injector cleaner? every tank? A guy I work with father out injector cleaner in every time he got gas.They ended up having to remove the tank to drain it. It wreaked havoc on the whole fuel system. Let me know about the cleaner then I have another test for you to do.
Old Jun 17, 2009 | 10:45 PM
  #73
suzuki-guy's Avatar
I did not use fuel system cleaner untill after the problem started. Ok what is my next task? And I just want to thank you once again for taking the time to help me out!
Old Jun 18, 2009 | 4:46 PM
  #74
suzuki-guy's Avatar
Bump!
Old Jun 18, 2009 | 7:39 PM
  #75
suzuki-guy's Avatar
Default collectors
I have the stock exhaust manifold on my truck and I am going to be deleting the y pipe on my truck. My question is can where can I get a collector that will work with my stock doghnut gasket? I want to run one seperate pipe from each manifold. And also what size collector do I need? I have 2.5 inch pipe on it so do i get 2.5 to 2.5 collector? Thanks guys.
Old Jun 19, 2009 | 4:41 AM
  #76
mudmaniac's Avatar
Ride of the Month
May 2009
Originally Posted by 1Gary
Cody-I am setting here in the cheap seats and watching how things are going.I will chime in as needed.Just wanted you to know I haven't abanded(sp) you.
Ditto, I'm watching but can't offer much help.
Old Jun 19, 2009 | 9:47 AM
  #77
suzuki-guy's Avatar
Thank's guys still havent heard from Mdtahoe though.
Old Jun 19, 2009 | 9:44 PM
  #78
MDTAHOE's Avatar
Tie your vac gauge in between your EGR valve and the vac switch. Drive it truck around and let me know if any vac is being applied to the EGR valve while the problem is happening.
Old Jun 27, 2009 | 6:03 PM
  #79
MDTAHOE's Avatar
Have you given up? I have not heard anything else? We can fix this truck
Old Jun 28, 2009 | 4:08 AM
  #80
suzuki-guy's Avatar
I have not given up Mdtahoe and I appreciate your strive to help me! I am replacing my clutch this weekend and hopefully I can get the Vacuum check in and report back to you monday! Once again thank's!
