Carburetor Rebuild or Replace?
Old Feb 17, 2023 | 10:29 PM
Velder's Avatar
Default Carburetor Rebuild or Replace?
Hello All,
I am a new member on this forum, but will probably be a regular as I am doing a complete renovation on a 85 Chevy C10.
My question right now is, about the carburetor, should I rebuild, or replace?
Been looking at some of those Holly or Edelbrock units and am wondering what the general consensus is, Replace or Rebuild?
I know I have problems with the carburetor, I have to crank for quite a while before she will start, not running real smooth, and dying unexpectedly. Maybe just a cracked seal?
I am replacing the entire fuel system, new gas tanks, fuel lines, vapor lines, pump, etc.
The current carburetor is the original Rochester 4bbl. I would prefer not to spend 500 bucks on a new one, but I really want this old girl to run good when I finish this project.
Any help, suggestions or opinions are greatly appreciated.
Old Feb 19, 2023 | 3:18 PM
you rebuilding or sending it out? if yr sending it out...what is the $ comparison vs new?
if you can find a kit with instructions for a good price...try it yourself.
Old Feb 19, 2023 | 5:21 PM
Velder's Avatar
I will be rebuilding it myself, I have no idea who I would send it to. do you know, Will the kit come with instructions?
Is there any where I could find more info on the process?
Thank you
Old Feb 19, 2023 | 7:54 PM
oilcanhenry's Avatar
Thank you
If its a Rochester Quadajet I'd dump it for a Holley. Tuning a Q-Jet is a PITA. If your throttle shaft is worn out, you need a new carb, as it's allowing unfiltered air into your motor and leaning it out as well.
Old Feb 19, 2023 | 8:54 PM
Velder's Avatar
It is a Quadajet, how do I tell if my throttle shaft is worn? when you say it is a pain to tune, is it something that can be done? or would I have to take it in?
If I were to swap it for a Holley, is there a particular one you would recommend?
Thank you
Old Feb 25, 2023 | 7:39 PM
Thank you
You'd need an expert on the Q-Jet like me, but I don't touch carburetors anymore. A 450-550 CFM Holley would work well, IMO. The trotter shaft is worn if it has play in it when you move it up, do and side to side. You can install bushinga but it a pain in the @$$.
Velder
17
Mar 9, 2023 9:23 PM
Chuckster2022
Jul 10, 2022 4:04 PM
Caleb Hershberger
Feb 25, 2020 11:04 PM
Tony Olsen
May 26, 2018 7:48 AM
sullivan_joshua
Feb 10, 2007 9:02 PM
