corroding transmission / transfer case
Old Jan 31, 2016 | 1:27 PM
rsmythe's Avatar
Default corroding transmission / transfer case
My 2001 silverado 1500 started leaking transmission fluid. My mechanic said the metel the transfer case and transmission are made from have started to corrode around the bolts and there was no way to fix it except replace both for several thousands of dollars. I know this isn't a new truck, but I certainly see lots and lots of much older silverado's on the road. It only has 100K miles and I've had the body work done in the last year so I hate to just scrap a fantastic truck, but it's not worth spending $5,000 for parts. Is this a common problem? Anyone have a less expensive fix idea?
Thank you very much!
Rich
Old Jan 31, 2016 | 1:34 PM
Rednucleus's Avatar
I would seek a second opinion at a reputable transmission shop in your area.
Old Jan 31, 2016 | 7:44 PM
cleveland63b's Avatar
or get pictures, would have to be pretty severe corrosion for that
Old Feb 2, 2016 | 6:50 AM
rsmythe's Avatar
Thank you, I'll get pictures tonight hopefully.
Old Feb 2, 2016 | 7:23 AM
never seen or heard of that an I worked in the rust belt for 5 years. Seems more likely to be a bad or missing gasket or someone use rtv instead of a gasket.
Old Mar 28, 2016 | 11:46 AM
rsmythe's Avatar
Default Pictures finally!
I've been trying to upload pictures for a couple weeks but they never show up. Fingers crossed...
Attached Thumbnails corroding transmission / transfer case-img_0751-copy.jpg   corroding transmission / transfer case-img_0755.jpg   corroding transmission / transfer case-img_0751.jpg
Old Mar 28, 2016 | 11:49 AM
rsmythe's Avatar
Default more pics
Thanks for your advice!
Attached Thumbnails corroding transmission / transfer case-img_0752-copy.jpg   corroding transmission / transfer case-img_0756.jpg
Old Mar 28, 2016 | 5:42 PM
the leak is from the transfer case itself, not the t-case to trans adaptor.
if it was mine I would separate the case and reseal it. the old sealant will leak after that many years.
google brny case repair for a video to split and reseal the case. Install a new oil pump retainer while your in there. install a new t-case to trans adaptor gasket. the fluid colour looks horrible.
