Doors lock on startup - 08 Envoy Denali
Old Mar 4, 2020 | 6:55 PM
Twowheeltimmy's Avatar
Default Doors lock on startup - 08 Envoy Denali
2008 GMC Envoy Denali 4x4
The doors lock a few seconds after the vehicle is started, door open or door closed, doesn't matter.
It makes it really easy to lock the keys inside with it running when you go to start it and warm it up. Super annoying. I've done a fair bit of research and couldn't find anyone with a similar issue.
Per the owners manual, Ive tried reprogramming the auto-lock. I have the same issue in mode 1 or 2. The first time I set it in program mode and tried to change the mode, I either get 2 fast dings, or 2 slow dings. There was no 1 ding. The second time, it seemed to work as it was supposed to, had the 1 ding and the 2 ding. Third try was the same as the first, 2 fast, or 2 slow dings. Regardless, neither mode should lock the doors on startup though. As far as I can tell, everything works as it should. How do I remedy this???
Old Mar 20, 2024 | 5:45 PM
Skiesfell's Avatar
I had to go into the program and set it to lock after vehicle is rolling - sry I can’t check the exact sequence because I can’t run the engine…long ugly story.
jlbeir
Jun 11, 2014 5:44 PM
Grapeape61
Jan 10, 2014 8:49 PM
millerlls220
Oct 15, 2013 7:33 PM
oldfireman0471
Apr 15, 2011 5:30 PM
dguy72
May 4, 2009 10:38 PM
