engine not firing on all cylinders
Old Jun 18, 2008 | 9:05 PM
1984s10guy's Avatar
Default engine not firing on all cylinders
Hello I have a 1984 chevy s10 truck in wich i installed a 267ci chevy v8 from a 1981 chevy monte carlo .
the problem i am having is that cylinder 6 and cylinder 8 don't seem to be firing ? I have spark at the wire and at the plug, and i seem to have good compression on the cylinders 160 psi I have the plug wires in the proper places on the distributer , now when i took out the plugs in these cylinders they seem to look like they got hot (whiteish) and have a little bit of black carbon deposits .
The motor sat fro aprox 4 years before installing it and running it .
could it be that the valves are sticking and not letting fuel into the cylinders?
or is it somthing total different and what can i do to fix this?
thanks in advance for any and all help.
Old Jun 18, 2008 | 9:31 PM
shawnvw's Avatar
Banned
Default RE: engine not firing on all cylinders
Sounds like the head gasket is broken between the 2 cylinders
Is the coolant low? is there white smoke when its running?
KeepNScore
Jan 15, 2021 7:43 PM
slownis
Mar 22, 2015 11:46 PM
nclark557
Mar 8, 2015 12:57 AM
70cst
Mar 1, 2015 3:18 PM
charms0
Aug 16, 2007 5:00 PM
