front differentail help
Old Nov 27, 2006 | 3:13 PM
redbear2008's Avatar
Default front differentail help
i have a 90 z71 the 4wd never worked then i shoved a rod in were the actuator goes and it dont seem to push far enough.. it wont lock in..you can feel it kinda grab just wont go all the way..so i took it out and put it in 4wd wouldnt kick in so drove a while the the front end started making a howling noise and i stopped the truck then the differential made a clunk noise and 4wd worked but soon as i took it out it wont work again the light is on on the floor saying it is in 4wd what is wrong with the differential
i hooked up the actuator up toggle switch and i no for sure the actuator pushes out but my differential dont seem to be locking i know for sure the t case works to it is something internal in differential.. could the actuator be weak???
Old Nov 29, 2006 | 1:09 AM
70mopar's Avatar
Default RE: front differentail help
sorry, can't seem to understand your one long sentence. r u saying u can manually override the system and get it 2 engage?
Old Feb 22, 2007 | 3:47 AM
btotheh33's Avatar
Are all 4 tires the same size? Are the gears behind the actuator sliding freely?
Bearpaafishin
Aug 11, 2014 7:34 AM
hunterjo
Jan 2, 2013 10:01 AM
Speedy650
Oct 10, 2009 7:01 PM
ruffrider285
Apr 30, 2007 1:25 AM
burnsze15
Dec 18, 2006 11:53 AM
