Here is a hard one for you techs
Old April 9th, 2009 | 11:05 PM
  #21
brandon1993's Avatar
Originally Posted by jeepmkcomin
Not sure if your vehicle has it but I have seen a coolant temp sensor cause similar symptoms.
it was replaced
Old April 9th, 2009 | 11:06 PM
  #22
Originally Posted by mudmaniac
Brandon,
Gary is right, I would check the voltage on the TPS you replaced.
I had a similar problem when I changed my intake and TB, I had a bad temp sensor and even though I set the TPS with a voltage meter I found that the meter did not equal the OBD 1 reading when checked with a scanner.
any idea what it should be when i check it?
Old April 10th, 2009 | 9:29 AM
  #23
I really doubt its the tps after having 2 in it, again when its warm it runs fine, after replacing all these parts I wonder if the timing might be slightly off, because it makes a poping noise through the throttle body, and the other day I seen it shoot fire out of it, when i had the aircleaner off.
Old April 10th, 2009 | 3:27 PM
  #24
mudmaniac's Avatar
Ride of the Month
May 2009
OK, check the timing and the TPS is 5 volts at WOT and I believe about .6 volts with no throttle, double check the .6 I can't remember for sure.
On71996
February 10th, 2011 7:21 PM
DeeZ
July 12th, 2009 2:39 PM
espy59lc
January 9th, 2009 2:30 PM
Dakota_Don
November 23rd, 2008 2:52 PM
brjray
November 6th, 2008 6:18 AM
Quick Reply: Here is a hard one for you techs
