how do i bleed the cooling system?
Old Dec 7, 2006 | 8:48 PM
dogz46's Avatar
Default how do i bleed the cooling system?
i get heat then no heat, the engine overheats then i put the heat on it drops a bit . i changed the stat,didnt help, with the heat off i open the little brass screw on the black pipe by the water pumpand i get steam , put the heater on i get antifreeze,pop the top on resevoir it gurgles and over flows. i no its full of air but how do i get rid of it all?? ive been at this for days. ( 97 3.1 malibu ) thanks.
Old Dec 8, 2006 | 6:10 AM
beckeruti's Avatar
Default RE: how do i bleed the cooling system?
are you sure you put the stat in the right way
sounds like it might be upside down
dont feel bad if it is
i have done it before
Old Dec 8, 2006 | 12:17 PM
dogz46's Avatar
spring towards the engine,it cant go any other way ,the housing you take off is way to shallow. i changed engines and the car sat for a day with no engine in it ,im 99% sure it just full of air. thanks anyway.
Old Dec 9, 2006 | 8:34 PM
dogz46's Avatar
if anyones interested,ijacked up the passenger front were the resivior is and rev it up to 2000 rpms with the heat on ,after about 30 secs the resivior spilled over let out a gurrgle (burp). i filled it back up and now alls well,lots of heat and temp needle stays right around the middle.
Leg0nd
Sep 27, 2013 1:24 AM
BillJ
Jul 10, 2013 7:27 PM
heavychevy63
Aug 6, 2008 7:40 PM
Waltmoe
Aug 31, 2007 11:33 AM
chevy3quarta
Jul 27, 2007 5:19 PM
