Just looking for advice
Old Aug 30, 2014 | 10:43 AM
Mike556177's Avatar
Default Just looking for advice
I have a 93 chevy silverdao.it has a 350,5 speed standard trans.I have decided to put an Eaton posi in it,but at the same time,I want to put a higher gear ratio in it.It has now.a 3.42 ratio.I cant decide on either a 3.55 or a 3.73,because of the 5 speed..any suggestions?Thank you.
Old Aug 31, 2014 | 12:12 PM
SWHouston's Avatar
Depends on what you want to do with it...
also, what's your final OD ratio ?
Old Aug 31, 2014 | 12:41 PM
Mike556177's Avatar
Thanks for the reply.I cant seem to find the final OD ratio,but at 2000 rpm,its doing 65 mph.I have found out that I was going in the wrong direction.It has 3.42 now.A higher ratio would be a 3.31 or a 3.23.So I guess the decision is between these two.
Old Aug 31, 2014 | 1:03 PM
SWHouston's Avatar
HA, those terms are totally confusing, but...
No, when your numbers go lower, then the ratio is lower too, so
a lower ratio is what you're after.
A 3.25:1 is a lower ratio than a 4.56:1.
Think proportionately. The :1 (to 1) is the reference.
I'll try to look into that 2000rpm/65mph and see what I can find.
So, you're trying to get more speed out of it, or...
lowering RPM's for...better mileage ?
Old Aug 31, 2014 | 3:32 PM
Mike556177's Avatar
A little better milage.
Old Aug 31, 2014 | 3:35 PM
Mike556177's Avatar
also,I understand if the numbers are lower,the ratio is higher..
Old Aug 31, 2014 | 5:29 PM
Mike556177's Avatar
I found this..Engine RPM / Engine Speed Calculator
Old Aug 31, 2014 | 11:29 PM
SWHouston's Avatar
Thanks for the link.
No, a low ratio would be a 1 to 1 (1:1),
A hi ratio would be like 10 to 1 (10:1).
When speaking of Differential Gear Ratio, the first number relates to turns of the drive shaft, to, one turn of the rear wheels.
Often times, we refer to 1st, 2nd, etc as our Low Gears, but, and that "low" reference often confuses this issue.
Furthermore, there are references to "Low Range". And actually both of the above are referring to speed, not ratio.
wallstreetamigo
Apr 3, 2010 7:13 AM
DrewSON
Jul 9, 2009 3:46 PM
95wt
May 5, 2008 2:45 PM
sonnys007
Apr 28, 2008 3:58 PM
