Old Jul 24, 2015, 4:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Knock sensor... HELP!!!!!!!
Old Feb 9, 2010 | 1:26 PM
jp24's Avatar
Default Knock sensor... HELP!!!!!!!
I need to replace the knock sensor in my 2005 silverado 2500HD. How do i do this? Where is it located? Any and all help is much appreciated!
Old Feb 9, 2010 | 1:44 PM
gmpartsguy's Avatar
hey man assuming you have a 6.0 engine. your knock sensors should be under your intake. replace your knock sensor wiring harness as well. just as common to go out as the sensors. get a set of intake gaskets and some coolant to go along with it. removing your intake is pretty strait forward. remove cooling hoses from throttle body disconnect throttle cables, fuel lines and other small connectors. take the bolts loose holding it on and pull it out. the sonsors will be directly in the middle of the engine. the sensors will be covered by some plugs. pull the plugs out, disconnect the connectors. remove sensors and reverse the process. but dont skimp on the wiring harness for the sensors. pm me if you have any more questions. you can call me too 214-472-6803
Old Feb 10, 2010 | 10:12 AM
cams 98 silverado's Avatar
i did not think that coolant ran into the intake on those motors? hey if your removin the intake. put a trail blazer SS intake on lol.
Old Feb 11, 2010 | 5:06 PM
jp24's Avatar
Thanks "gmpartsguy" As soon as the snow clears out of here i will try it! Im sure more questions will be coming....LOL
chdonley
Jun 25, 2013 10:04 AM
shawnn
Oct 17, 2011 8:02 PM
mulchman61
Nov 6, 2010 9:57 AM
jffgin
Mar 10, 2008 2:32 PM
