No Heat on the floor?
Old Dec 29, 2010 | 9:14 PM
budmano63's Avatar
Default No Heat on the floor?
ok my heat comes out of the defrost but not out of the foor even when the **** is on floor it comes out of defrost...the heat works fine on the top by my face but not to the floor so defrost and head vents work but no heat to floor anybody have any ideas?
Old Jan 1, 2011 | 5:20 AM
thomas_Oct17's Avatar
Default Reply
I don't have any ideas.
Old Jan 1, 2011 | 12:37 PM
92chevysilvy's Avatar
Classifieds Moderator
TruckForums Liaison
Luckily, this is the easiest flap to get to!
down under your dash in the middle you'll see a black box. On the driver side of that box you'll see a little gear motor. If the selector to the face vents is still working, I would assume tthat gear motor is good. The motor will have two levers attaching to it that operate a couple of flaps. One flap controls the defroster and the other does the floor to face vents. You might get lucky and find that the lever has just come disconnected, but I had to wriggle my hand way up inside the dash after disassembling it to place the flap back in it's slots.
I'm not sure what you drive, but I'm assuming that it's a similar GM configuration because it seems to be a common problem
cbarnes1976
Aug 6, 2014 8:32 PM
tbohling
Colorado
Jun 22, 2011 7:56 PM
maxxmusle
Sep 6, 2008 5:50 PM
jmitchell
Apr 17, 2007 2:09 PM
tumark
Apr 15, 2007 12:58 PM
