P0010 code after oil change
Old Dec 6, 2009 | 10:38 PM
chemman's Avatar
Default P0010 code after oil change
My wife's '06 Uplander had a low oil level warning the other day and was time to change it anyway, so I gave it an oil change. I don't find any leaks, I think the darn thing burns oil and with only 39k miles. I have been using synthetic since I bought it, I decided to switch back to conventional to see if the oil loss gets better.
Anyway, now I get a P0010 (intake camshaft position actuator solenoid) error code. Also, shifting is now jerky, this seems common with the error code from what I have read from my internet searches. I also have read that the code sometimes comes up after low oil warning and that the actuator is hydraulically driven. Do you think there is a actual failure? Does the ECM need to be retrained or cleared in someway?
Old Dec 7, 2009 | 7:23 PM
chemman's Avatar
I just found this:
A code P0010 may mean that one or more of the following has happened:
  • Faulty oil control valve (OCV)
  • Open or short in the VVT/VCT circuit
  • Open or short in the OCV / solenoid valve
  • Damaged computer (PCM)
Does anyone know the location of the OCV, or the correct GM naming?
Old Dec 8, 2009 | 12:42 PM
chemman's Avatar
Now the battery is dead, reading 5.8 V under no load.
89scottsdale
Nov 29, 2014 9:15 PM
Erockhandyman
Apr 27, 2010 9:14 PM
mitranom
Avalanche
Feb 27, 2008 3:11 PM
MC
Aug 24, 2007 10:27 PM
digdug
Feb 4, 2007 3:08 PM
