P1345 code from 2001 Safari???
Old Dec 11, 2006 | 2:23 AM
redvette's Avatar
Default P1345 code from 2001 Safari???
My 2001 GMC Safari has a service engine soon code of P1345.
The van has 75k and never had a problem until now. I did change
the cap and rotor and the light came back on. Please help
redvette
Old Dec 11, 2006 | 1:18 PM
golfer's Avatar
Default RE: P1345 code from 2001 Safari???
ORIGINAL: redvette
redvette
Well your code P1345 = Camshaft to Crankshaft position Sensor Correction Fault
Changing the cap and rotor ( although wouldn't hurt ) won't correct this fault.
There is a problem with the cam position sensor circuit or the crank position circuit.
Old Dec 11, 2006 | 8:06 PM
redvette's Avatar
Thanks for the help. The engine was also making a slight tapping noise from the front.
I replaced the Crankshaft Position Sensor and the noise stopped and the check engine light is now off. The part was $60 at AutoZone and they loan you the OBCII Scanner at the store.
Redvette
Old Dec 13, 2006 | 2:20 AM
redvette's Avatar
The check engine light returned;
Now do I need to replace the cam position sensor??????
P1345 code..
Old Dec 15, 2006 | 8:48 PM
redvette's Avatar
Installed new cam position sensor and the damn light is still on.
Any help would be appreciated,, thanks.
Old Dec 16, 2006 | 8:59 AM
beckeruti's Avatar
try disconnecting the battery for a bit to see if that will reset the computer
or u might have to have the code cleared with a scantool of some sort
assuming that the problem is fixed
good luck
Old Dec 16, 2006 | 4:32 PM
redvette's Avatar
Thanks, I cleared the code with a scan tool, but it comes right back.
Any other suggestions???
seamorewatervip
Jan 14, 2013 6:13 PM
thetimguy
Apr 20, 2010 5:29 PM
pepq105
Jan 10, 2010 9:24 PM
sushibog66
Aug 17, 2009 4:24 AM
