rear popping
Old Mar 17, 2008 | 7:55 PM
redneck 4 life's Avatar
Default rear popping
I have a 1994 chevy 1500 and when its cold after starting and leting it warm up for a little bit i put it in gear and start moving it pops a couple of times then it gose away what is this popping?
thanks
Old Mar 18, 2008 | 10:37 AM
TransAm Man's Avatar
Default RE: rear popping
I have a feeling that your rear end gear oil fluid might be low. It sounds like when you let the truck sit over night all the fluid drains off the gears, when there is no fluid it makes a popping sound, socheck your fluid level and see what happens. Unless, you didn't put a lift kit on your truck did you? If you did your fluid might not be low it could just be at a different level point.
Old Mar 19, 2008 | 4:57 PM
no i dont have a lift kits yet so ill try that
thanks
Old Mar 22, 2008 | 8:36 PM
jkgray80's Avatar
Check your u-joints.
Old Mar 24, 2008 | 12:11 PM
mitchell03's Avatar
If your fluid level is okay and u joints i would suggest checking your pinion bearing I had this prob. on a 98
catch22
Apr 7, 2010 3:45 AM
biglg
Oct 16, 2006 1:05 PM
05impala
Sep 26, 2006 2:45 PM
gassman
Aug 12, 2006 3:17 PM
southernrebel05
May 5, 2005 3:16 PM
