starter continues to crank
Old Oct 7, 2012 | 8:17 AM
confused's Avatar
Default starter continues to crank
06 equinox starter continues to crank saw a post in equinox forum about cleaning throtle body. does the pcm control starter? pcm not reckognize that the engine is running?
Old Oct 11, 2012 | 5:52 PM
confused's Avatar
ok found an answer. pcm does control starter.gm shop manager said computer senses fuel in intake, can continue to crank up to 9 seconds. fctory program to prevent backfire causing plastic imtake to break. then he said try to convince a customer on the service drive of that. seems to be comon in several modles/years. said cleaning throtle body and adding injector cleaner can help. was this b.s. ANY IDEAS??
Old Oct 13, 2012 | 1:21 PM
confused's Avatar
talked to 2 techs at private shop. both said corperate B.S. fuel injected into intake runners in head. can't be fuel in intake, way to many sensors to tell pcm engine is running.posible starter drive draging, timer in pcm problem. found post in something like alldata don't know which log on service it was. no crank/continues to crank said it was a junction block under hood bad conection. come on guys somebody has an answer to this. THANKS IN ADVANCE.
Old Oct 14, 2012 | 6:15 AM
Are you describing a starter pinion to flywheel clash or a condition when you release the key the starter cranks by itself but no clash occurs?
does the gear clash occur once briefly after start-up or randomly while the car is running?
the starter could be hanging up. The electrical portion of the ignition switch could be could be bad.
Old Oct 14, 2012 | 8:05 AM
confused's Avatar
more like turn key to crank and engine starts. release key to run position,sounds like starter motor is still cranking 1/2 -3 seconds. very intermitent, sometimes will do it several times in a row. dosen't seem to have anything to do with engine or air temp. most of the time it won't do it. no grind or whir noise. ignition switch always springs back. replaced lock cylinder thoght it could be draging. these cyls. are prone to eating keys and self destructing. thought that fixed it. don't think it's in the switch. will see the car later today.
Old Oct 14, 2012 | 10:19 PM
the start request is ecm controlled so even if you hold the key in start after it starts it shouldn't grind. A mechanical key cylinder problem will not cause this as you have found out.
a starter pinion that is slow to disengage or has clearance problems usually make a ringing noise.
Old Oct 15, 2012 | 8:42 PM
hockemap's Avatar
I guess only time will tell.
Old Oct 16, 2012 | 3:13 PM
Official GM Rep
confused,
If you want for us to check into this further with your involved dealership, please contact us via private message or email (include your name, contact information, the last 8 digits of your VIN and the name of your involved dealership, as well as a summary of the situation).
Sarah (Assisting Louis), Chevrolet Customer Service
Duece
Oct 2, 2012 7:29 PM
suzuki-guy
Apr 27, 2009 9:37 PM
livlifes2short
Feb 20, 2009 7:47 AM
