Starter not contacting flywheel.
Old May 10, 2013 | 10:20 PM
14medlak's Avatar
Default Starter not contacting flywheel.
As you can see the starter isn't touching the flywheel. Or really close at all it's a 350 small block. And a small block starter. Not sure what is wrong. Or how to fix it without getting a new starter. And if I do need a new starter what do I need to get? It's a 1975 engine.
Old May 11, 2013 | 6:59 AM
tymr287's Avatar
What kind of work was done before this happened? Just asking, because it seems like the flywheel is the wrong size diameter.
Old May 11, 2013 | 7:10 AM
kevinkpk's Avatar
In this case a starter is a starter. I've had to shim some, but in this case something is WAY out of wack.
Old May 11, 2013 | 7:53 AM
14medlak's Avatar
Not really any work has been done. My dad is thinking its the wrong fly wheel to. So I'm considering ordering a new one. It just doesn't make sense because the motor ran when my neighbor had it with a different starter. If I do order a new fly wheel should I get a 153 tooth or 168?
Old May 11, 2013 | 7:59 AM
tymr287's Avatar
You stated it ran with a different starter. You need to find out what starter he had on it before it was replaced.
Old May 11, 2013 | 8:22 AM
14medlak's Avatar
It did run but that starter needed a new solenoid. I'm gonna ask him today to look at it and ill get a picture of it. But would it be easier just replacing the flywheel than trying to find a special starter for it?
Old May 11, 2013 | 10:09 AM
tymr287's Avatar
I'd make sure the old starter is a match to the one you just put on. The housing for the bendix could be different.
Old May 11, 2013 | 11:20 AM
14medlak's Avatar
My neighbor had a 168 tooth flywheel sitting around that he gave to us. I got yhe old starter that was on it too but it's junk. We're just gonna pull the engine and change the flywheel with the bigger one. Thank you all for the help.
Old May 15, 2013 | 3:36 PM
Camaro 69's Avatar
Site Ambassador
You have the staggered mount starter which is what's used with the 168 tooth flexplate. But your engine has the 153 tooth flexplate on it. What you need is the straight across mount starter which will put the starter closer to the flexplate. I can see part of the third hole just below the flexplate gear, which means your block is dual drilled. Yanking it all apart to put on the 168 tooth flexplate is a lot of extra and unnecessary work.
Old Nov 7, 2014 | 5:52 PM
midget77's Avatar
Default three hole missing
My problem is that my 350 doesn't have the third hole. I switched from a 168 to a 153 to use a 3 speed standard clutch. Any idea on finding an angled starter that would work on a 153 flywheel?
johnsonn
Traverse
Jun 19, 2015 9:09 AM
a_plus
Jul 2, 2011 12:20 PM
LilManDavis
Jun 22, 2008 10:41 AM
sbudac
Mar 20, 2007 4:38 PM
Zeke
Sep 27, 2006 2:32 PM
