starter question
Old Feb 10, 2011 | 6:35 PM
steven7685's Avatar
Default starter question
ive been having issues with some of the old wiring that connects to the starter in my 1977 oldsmobile cutlass supreme. so today i decided to pull the starter out again and see if i can fix this problem yet again...
everything went fine removing the starter, except when i went to remove the smaller nut with the small wire (ground??) where the wire had been old and brittle, i had the wire snapped in half with metal eye connected to the bolt. when i attempted to remove the nut, the bolt just snapped and there is nothing protruding to re attach this wire to after i re-connect the metal eye.
that may sound confusing but i can assure you that it is my lack of mechanical aptitude that makes it sound worse than it is .
ill attach pictures of what im talking about.
but my question was, is there any way i can fix this thing without replacing the entire starter? it is a newer starter with nothing else wrong with it. (probably has 200 starts on it)
any help,tips or instructions would be greatly appreciated. thanks!
Attached Thumbnails starter question-starter-1.jpg   starter question-starter-2.jpg   starter question-starter3.jpg
Old Feb 10, 2011 | 7:43 PM
steven7685's Avatar
Default lol
my roomie just made me feel stupid when he laughed and said thats the solenoid.
im looking into replacing it.
got the 3 bolts off but dont want to force anything to free the solenoid.
any suggestions would be great!
Old Feb 10, 2011 | 9:41 PM
OLD WRENCH's Avatar
Default starter
If you got all the wires off and screws out give it a quarter turn and it should come off. When I run in to one that acts this way I cut the wire and splce it back when I get done. If you can find a bolt out of an old one you might be able to replace it.
bavant
Jan 16, 2012 2:12 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
bbtahoe
Oct 21, 2006 1:19 AM
sonicstyle
Sep 9, 2006 11:45 PM
