Tranmission pressure sensor solenoid
Old Oct 1, 2014 | 9:26 AM
deaner's Avatar
Default Tranmission pressure sensor solenoid
Hello, I have two automobiles, a 2006 Chevy Impala 3.5 and a 2007 Chevy Uplander 3.9. The transmission in both cars (lucky me) will occationaly slip in first gear. This usually happens when the engine is cold. The engine will rev and then it will jerk forwad when the tranny finally engages. I've read where this could be a bad pressure control solenoid and the only way to fix this is to pull the plate on the side of the tranny and replace. Estimates are araound $800-$1000. Is this a common problem throughout GM products? Is there a positive way to know if it's actually the PCS? It's not throwing any codes that I can tell. I've also read where this could be just a dirty or clogged PCS? And maybe just running some tranny cleaner thru might fix? That's probably just whishfull thinking. Anyone else experience this? This is very frustrating to have the same problem develop in both of my GM cars.
Old Aug 3, 2015 | 9:09 PM
madmedix's Avatar
Deaner,
Still have the car and van? There is a YouTube video of a guy showing you how to change that solenoid by accessing it from the right front side (half-shaft removed). Search youtube 2006 uplander transmission and you'll find this
. This guy gives a great overview.
Old Aug 11, 2015 | 6:03 AM
gsferraro's Avatar
Hello,
Does this problem happen in reverse? Does the problem happen all the time or just when hot or cold. Gary
Box Chev
May 16, 2011 12:48 AM
nub
Sep 30, 2009 2:54 PM
g-rod
Jun 17, 2009 12:00 AM
dbkd96
Sep 24, 2008 5:30 PM
folmsbee
Apr 2, 2008 2:40 AM
