Tranny questions
Old Oct 9, 2014 | 4:42 PM
Mafew14's Avatar
Default Tranny questions
I have a short box 1982 Chevy 1/2 ton and the tranny in it need a rebuild it's and automatic but instead of rebuilding it I would like to put a manual tranny in. But the tranny that it would be coming out of is a long box Chevy. So my question is... Are the trannys from a long box different size to a short box? Can I just swap them out and everything will be perfect or will the drive shaft need modifications?
Thanks!
Old Oct 15, 2014 | 3:51 PM
ThatChevyGuy's Avatar
the transmission between the long box and short box are the same (the driveshaft is the difference. now the manual transmission will probably have a different length than the automatic transmission, but hopefully it is close enough that you can use the same driveshaft.
obviously you will need:
1. Bell housing
2. Clutch
3. Crossmember
4. a way to do a Pedal conversion
5. Linkage for your clutch pedal
6. Gear shifter
are you getting all this out of the long box?
A. T
Nov 29, 2011 5:03 PM
DeHartShadow
Mar 28, 2010 10:10 PM
89silverado283
Feb 16, 2010 8:50 AM
revamped
Aug 24, 2008 10:48 PM
revamped
Jan 23, 2008 4:03 PM
