Valve Spring removal
Old Nov 9, 2022 | 7:02 AM
mmartin8888's Avatar
Default Valve Spring removal
So I am work on a old 396 and I have the heads off but the valves keep moving when I am trying to remove the springs. Any tricks to help with this?
Old Nov 9, 2022 | 7:32 AM
Welcome from Florida. Which removal tool are you using? With a good removal tool the valves should not be moving.
Old Nov 9, 2022 | 10:56 AM
Hello from North Carolina, I might be asking a ton of questions lol I am taking part apart a 1969 396/375 or more HP four bolt main to rebuild for my car and trust me I will have help putting it back together but for now I am breaking it down. I am not sure if some of the issue is the performance added springs making it tough it is the springs within the springs.I I am using the tool with the two prongs and the star handle you tighten down.
If you suggest a better one please do I got one off after a bout 3 hours lol
Old Nov 9, 2022 | 2:24 PM
I use one similar to this one and have no problems with it.
Old Nov 9, 2022 | 4:37 PM
Thank you that would work I just ordered one. Do you know if the one bolt holding the harmonic balancer how do you keep it from rotating to get the bolt off?
Old Nov 10, 2022 | 7:25 AM
You can use an impact wrench.
TahoeMatt
Feb 28, 2013 8:13 PM
stanman
Jul 11, 2011 12:16 AM
kcoutlaw
Nov 6, 2010 11:04 PM
