Van won't start, no clicking just dead silence
Old Apr 29, 2010 | 12:46 PM
veggs2000's Avatar
Default Van won't start, no clicking just dead silence
I have a 2002 Chevy Express 3500 with 56,000 miles (5.7L). It had two new starters in 2009 after the first one failed within a couple weeks and also had a new battery in at that time. In January of this year the fuel pump and distributor cap were replaced and we thought that was the end of our problems.
Then yesterday out of nowhere it wouldn't start. It makes no sounds like it is trying to start and all lights and radio come on fine. Then after several tries it will usually start, it has been very hit and miss but when it starts it is fine.
Any ideas? I have put more money into this van in a very short time then any other vehicle I've ever owned.
Old Apr 30, 2010 | 5:46 PM
desrtrat's Avatar
check your starter relay. you can swap out with the AC relay to see if it starts..
good luck
Old May 1, 2010 | 3:01 PM
therewolf's Avatar
Hi veggs2000,
Welcome to the Chevy Forums.
Change your battery cables. Don't forget the bolts.
Old May 4, 2010 | 1:59 PM
veggs2000's Avatar
Thanks
I was wrong about no noise, you can clearly hear the starter clicking with each turn when the door is open.
Old May 4, 2010 | 3:14 PM
desrtrat's Avatar
take the starter in for a bench test, along with the battery for a load test.. check all grounds, and cable ends for corrosion
good luck
scuba_steveo
May 9, 2022 3:47 PM
Jessica Pulido
Mar 16, 2013 7:35 PM
jrhody
Mar 28, 2011 10:15 PM
