Vehicle Theft Deterrent, Passlock System - All previous posted methods failed
Old Jan 3, 2015 | 9:49 PM
  #11
corndawg's Avatar
Default passlock issue
i have fuel pressure and fire. compression and timing are good, my security light comes on for a second then goes off but its like my fuel injectors are not working. could this still be a passlock issue? it wont even start for a second like the videos ive seen but it will turn over.
Old Jan 4, 2015 | 10:15 AM
  #12
you have a different vehicle so not everything posted will apply. the security light should come on continuously if there is a passlock event.
how much fuel pressure do you have? port poppet style fuel injectors will not open if the fuel pressure is 40psi or lower iirc.
Old Feb 20, 2015 | 6:28 AM
  #13
leemike's Avatar
Nice discussion about the vehicles.
I was looking for such form where I could learn.
Old Jan 18, 2022 | 11:16 AM
  #14
Chevy express 2005 Simon's Avatar
Hello,
I have a bit the same problem on a Chevy Express 2500, 2005 and it is killing me.
Randomnly the van doesnt start even if it crank well, most of the times after I parked it for 10-30 minutes.
Randomnly the van stall while driving. (Kind of dangerous)
Every time it happen, it doesnt start if I crank it right after, or 1 or 2 minute after, but ALWAYS start if I wait 10 minutes and start back. (passlock learning procedure???)
Note that when it is not starting it is not hesitating at ALL, and when it does start after it start right on easily and sharp-clean.
I have seen the security light 2 or 3 time but the problem happened 50 times since 2 years. more and more often.
I have unplugged and plug back the small security wire on the key cylinder and now the security light is always ON. And van is starting anyway even with the light on.
Thank for your help and time!
atex33
Aug 30, 2024 1:00 PM
Coby Owner_2006
Cobalt
Sep 29, 2019 2:30 PM
twins225
28
Sep 16, 2019 11:57 AM
wildcat682
Feb 13, 2015 8:38 PM
gdmurf
Mar 9, 2009 7:21 AM
