HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
front end noise
Old May 19, 2020 | 11:07 AM
daveydeuce's Avatar
Question front end noise
Our HHR has slowly developed a strange front suspension noise. Sounds like possible wheel bearing however on a hoist running in gear sounds more like in transaxle. faster the speed, the noisier in all gears (MANUAL TRANS). not running all seems to be tight, no shaking or wiggling, no hand movement. on the road it sounds like driver front. Been a Auto Mech since the 50s, hate to tear it apart till I get more info on possible probs. Thanx in advance, any help will be appreciated. Was the Father in laws, his passing left it to my wife. He bought it new on OK. 98K miles.
Old May 19, 2020 | 6:03 PM
does the noise change as the vehicle is swayed left and right to load and unload the wheel bearings?
Old May 20, 2020 | 2:33 PM
daveydeuce's Avatar
Default front end noise
NO, tried that, thought the same thing. Thanx
Old May 20, 2020 | 9:10 PM
its a lot of work; that model has small stubs shafts that join the axle shafts and transaxle... you could remove the cv shafts...leaving the stub shaft in the transmission and then run on hoist. if it is the transaxle....axles are out for the randr
Old May 21, 2020 | 11:21 PM
daveydeuce's Avatar
will try that Thanx
frederick1010
Nov 26, 2018 4:33 PM
Will Mosher
Apr 3, 2017 5:41 PM
johnhoferer@yahoo.com
Nov 4, 2014 6:05 PM
millerlls220
Sep 27, 2013 5:27 PM
Mr.Cale
Jan 15, 2012 5:39 PM
