HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Rolling in Park
Old Mar 16, 2013 | 8:50 AM
racecardude's Avatar
Default Rolling in Park
The wife shifted into park accidentally on the highway. The park mechanism broke. I believe its called the parking pawl...
I have searched far and wide and cannot find information on how to replace this part, or even a proper diagnosis / part number... I'm not going to pay a mechanic $1000 to replaced a $30 part.
Symptoms: Car rolls while in park.
YMM: 2006 Chevy HHR LT 2.2L
Can someone confirm the name of the part is a parking pawl, and tell me how I might go about replacing said part?
For perspective, I have done full engine removals and rebuilds in the past, so I am pretty proficient mechanically. However I have not successfully fixed a transmission issue before.
Old Mar 16, 2013 | 12:32 PM
Found my answer on AKO. THANK YOU Army... lol:
  1. Remove the manual shaft to transmission case pin (803).ImportantThe parking lock actuator assembly (807) remains attached to the manual shaft and detent lever until the assembly is removed.
  2. Remove the manual shaft and detent lever assembly (806) by pushing the manual shaft into the transmission case (51). The parking lock actuator assembly (807) remains attached to the detent lever until you remove the manual shaft and detent lever assembly.Caution! Do not damage the case bore during removal of the manual shift shaft seal.
  3. Remove the manual shaft seal (809) from the case (51).
In other words... I get to pull the AT.... Lovely.
Old Mar 16, 2013 | 12:34 PM
Manual Shift Shaft Pin, Detent Lever, and Park Pawl Actuator Assembly Installation
Tools Required
J 41229 Manual Shaft to Case Pin Installer or equivalent
  1. [*]
  2. [*]
  3. [*]
  4. [*]
Cornfuzzled
Mar 2, 2014 2:32 PM
Chevrolet Forum News
Mar 26, 2013 8:38 AM
Julianftw
Apr 9, 2010 12:48 PM
jonbert
Dec 20, 2008 2:16 PM
Derek2023
Jul 20, 2007 5:34 PM
