2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2000 Impala LS ABS & traction light, code c1218
Old Oct 12, 2006 | 12:42 AM
mnm567's Avatar
Default 2000 Impala LS ABS & traction light, code c1218
Hello,
I am new to this site and have dealt with forums before. A great source of information! My problem is with a 2000 Impala Ls. I have a constant ABS and Traction control light emitted. The code was retrieved and it was code C1218. It states: Pump motor circuit shorted to voltage. Does anyone know where to start? This car had an aftermarket remote starter installed about 2 years ago. I don't know if this would have anything to do with it, but you never know. When the car was scanned for codes, the shop said it was possibly a bad ground to the motor. Any information would help tremendously. Thanks in advance, Matt
Old Jan 3, 2007 | 11:45 AM
LatinPride613's Avatar
Default RE: 2000 Impala LS ABS & traction light, code c1218
I also have the exact same problem with my 2003 impala. I see that we arent the only ones with this problem. Please someone help!!
Old Jan 3, 2007 | 12:17 PM
mnm567's Avatar
I figured it out. I loosened the ground wire that goes from the ABS motor to the body. And roughed up the surfaces. Put the ground wire back on and boom, the light is gone. It was funny, cause every time we washed the car, the light would go away for awhile. The water would create a good ground. I hope this fix works for everyone else. Thanks, Matt
Old Jan 3, 2007 | 8:33 PM
golfer's Avatar
ORIGINAL: mnm567
Nice fix ...thanks for the follow up.
Old Jun 12, 2007 | 5:47 PM
alleydude's Avatar
ORIGINAL: mnm567
I'm having the same %$#! problem. WHere is the ABS motor located. Thank you for the hope of fixing this thing...!
Ken
Old Nov 21, 2012 | 10:30 AM
re54drider's Avatar
Great thread! I tried cleaning up the ground but no go. I had to run a new wire from the top left screw of the module to the throttle body. Works great! BTW, the module is underneath the cruise control next to the master cylinder.
Old Nov 21, 2012 | 11:43 AM
re54drider Welcome to the forum
Thanks for following up with what worked for you
Old May 30, 2014 | 1:43 PM
dedesylvie's Avatar
thank you everybody, its working very good for me, make my day!!!
Old Feb 14, 2016 | 6:18 PM
Dorlow's Avatar
worked for me. i just disconnected the ground to the frame under the ABS module. (When I did that, the bolt broke in half indicating a problem there.) I then ran it around the front (in a plastic sleeve) to the negative battery terminal. ABS and TC work great now.
smar1278
Aug 24, 2015 1:18 AM
idk2050
Mar 24, 2015 9:32 AM
Bob S
Nov 4, 2010 12:21 PM
mnm567
Oct 12, 2006 12:41 AM
bbur7
Sep 1, 2006 10:06 PM
