2000-PRESENT Impala Keyless Entry Re-Programs
I've followed these steps to the "T" and nothing.
Here's what I did. Found another link saying the same steps with the exception of
1 put key in ignition
2 turn key to "ACC"
And then the steps above are the same from there.
I get into the sub menu press "prev" button prog fob hit the disp button to begin programming. But nothing flashes. I still held the lock and unlock buttons and nothing happens. It just times out and I have to start over. Please advise thank you
2 turn key to "ACC"
I just bought a 2006 Impala LT. The keyfob wasnt working. I replaced the battery and took it to autozone and had it tested and it works fine. Here is my question, maybe a dumb one. I have tried following the directions on re-programming it. I get to the press Vehicle information button until "PRESS [checkmark] (set/reset)TO RELEARN REMOTE KEY" displays part and no matter what i do i can not get the REMOTE KEY LEARNING ACTIVE to display. I have held reset down and have also pressed reset repeatedly. Am i doing something wrong? Do i press reset and hold until it says remote key learning active? and if so about how long? Or do i press repeatedly? Any help is appreciated. Thanks!!
How did you fix this problem.)
2006-2008 Impala WITH Driver Information Center (DIC) Buttons
Keyless Re-program Instructions
Legend:
Insert key and turn ignition switch to "On"
Follow these steps:
-Press Vehicle information button until "PRESS [checkmark] (set/reset)TO RELEARN REMOTE KEY" displays.
-Press Set/Reset button until "REMOTE KEY LEARNING ACTIVE" displays.
-Press and hold both the Lock and Unlock buttons on the keyless remote for approximately 15 seconds. A chime will sound to indicate that the remote is programmed.
-To program additional remotes, repeat step 3. A maximum of 8 remotes can be programmed to this vehicle.
-Exit programming mode by turning key to "Off" position.
-Test Remote(s)
Legend:
Follow these steps:
-Test Remote(s)
Legend:
Follow these steps:
-Test Remote(s)
Legend:
Follow these steps:
-Test Remote(s)
After taking the car to the dealer for some unrelated repairs, my remotes started working again. I was told there was an update to the ECM software. I sure hope this info helps someone else! I do have the receipt from the dealer that says exactly what was done. I will be happy to pass that along if that would be of any benefit to anyone.
Hello,
I have searched this thread for the relevant solution but here's the problem: This is a 2015 Impala 2LTZ with keyless entry and ignition. I'm trying to program an OEM fob/remote and I've painstakingly followed the instructions in the manual, as well as searched other websites and YouTube videos to no avail. Multiple times I've tried the procedure and nothing happens. I've tried with the door open and me standing outside, tried sitting in the car with the door closed, heck I'd stand on my head if I thought it would help.
I turn the flip key five times to the left like everyone says and I don't even get the DIC display to indicate it knows anything's happening. I turn it slow, I turn it fast. No matter what I do I can't go any further as I see no changes in the DIC. Is there anyone who can help? I've about ripped out what little hair I have left. Thank you! ~IdahoJoe
baby bobby
Feb 4, 2014 2:52 AM
