2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2001 Impala Base Electrical Issues
Old May 6, 2023 | 1:11 PM
Originalsboy's Avatar
Default 2001 Impala Base Electrical Issues
So I've been having a battle with this car's electrical system and it's driving me nuts. It seems when the weather gets warm (<60 Degrees Fahrenheit), the car seems to act nuts electrically. The first electrical malfunction symptom I got was last night when the "Trunk Open" message on the dashboard on stays on when the trunk is closed and turns off when it's open. Then today when I drove it to work, the door lock refused to unlock when I put it in park and now when I restart the car, the radio locked up and displayed a "LOCKED" message onscreen. From what I've know, the battery tested good, ignition barrel has been changed and connections are good. Would this the fault of a bad BCM or Ignition Switch?
Thanks in advance!
EDIT:
When I drove it home after letting it sit for ~4 hours and it's slightly cooler outside, the radio is unlocked and worked with no problems, when I got it home, the door unlocked for me when I put it in park with no issue. The "Trunk Open" quirk is still present.
JasperTheFloof
May 5, 2021 11:07 AM
Reinam
Feb 27, 2021 12:11 PM
Itoc
Apr 22, 2015 2:03 PM
Angel239
May 15, 2014 5:32 PM
yourmanhood
Jul 6, 2011 9:41 PM
