2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Old Jul 22, 2015, 10:19 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
2003 Impala Brake question
Old Mar 28, 2010 | 6:07 AM
philll74's Avatar
Default 2003 Impala Brake question
I am needing to change the brakes on a friends 2003 Impala LS. I will probably have to replace the rotors as well or at least have them turned. Is there any issues or concerns that I will need to look forward to when I do this. I have changed my own brakes on older vehicles but also on my newer cars but mainly dodge products. Just wanted a some friendly help if there is something I need to be aware of. I will also be looking at the rear brakes, is there any issues there also? Thanks in advance for any help. Paul
Old Mar 28, 2010 | 1:06 PM
s34n's Avatar
my mom has an 02 impala and i've done front and back brakes on it. everything is straight forward. i didnt have any problems while doing them.
Old Mar 28, 2010 | 4:21 PM
philll74's Avatar
Default Thanks
That is what I like to hear. Was just trying to get a heads up on any possible pitfalls that I wasnt aware of. Thanks again, Paul
Old Mar 28, 2010 | 4:35 PM
s34n's Avatar
hey paul, no problem. just a couple bolts on the caliper bracket and two for the caliper on each. my suggestion would be to use ceramic brake pads. they put out less dust and last alot longer then semi metallic.
Old Mar 28, 2010 | 10:18 PM
Gwampa's Avatar
Talking
s34n, won't he have to take the bracket off the spindle to replace the rotor? When replacing the bracket, should those bolts be torqued or just tighten the crap out of them? Also the ceramic pads are tops. MDTahoe recommended a Japanese pad (something like achin boner). Ain't I just a riot!
Old Mar 28, 2010 | 10:53 PM
s34n's Avatar
gwampa, he will have to take the bracket off the spindle. i've always just tightened them as much as possible. those bolts are next to impossible to break. make sure to use loctite on the thread for the bracket and caliper bolts. also remember to grease the pins.
Old Mar 29, 2010 | 7:09 PM
capucine's Avatar
Very easy to replace. For your rotors instead of turning them go and buy a new set. Turned rotors dont last very long and within a short time you will end up with brakes pulsations. Now you can find rotors made in china and after trying them myself on my 2003 Impala I found that they lasted as long as the originals for a fraction of the price than the OE ones.
Slobby Baymon
Nov 12, 2013 11:52 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
Brian_Vesson
Oct 23, 2006 4:25 PM
jondoe28
Jun 27, 2006 4:14 PM
