2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2003 impala cooling fans will not start
Old Nov 1, 2021 | 7:15 PM
rocky10954's Avatar
Red face 2003 impala cooling fans will not start
hi , I bought a 2003 impala cooling fans will not start ?/
any ideas, please post many thanks, rocky
Old Nov 2, 2021 | 6:48 AM
kevinkpk's Avatar
It\they may not be required. One should come on with the ac on, have you tried that?
Old Nov 2, 2021 | 7:19 AM
Does the car overheat?
Old Nov 2, 2021 | 1:19 PM
rocky10954's Avatar
hi , I just bought this car , plan on registering it this week and getting plates, I changed the anit freeze,
I put on the a/c and ran the car in 50 degree weather
highest temperature idling was 200 degrees and no fans went on.
as I have said car used car i recently bought,
any ideas please post.
many thanks, rocky
Old Nov 12, 2021 | 3:40 PM
rocky10954's Avatar
hi guys , i have the impala on the road , ran the
car for 20 minutes , heater hoses are hot to the touch.
fans did not come on , at what temperature are the
fans set to come on ??
planning on taking a long trip thanksgiving, fear breaking done overheating.
sorry to be a pain , just at the age you hate to break down on the road,
please post, many thanks, rocky
Old Nov 12, 2021 | 3:52 PM
kevinkpk's Avatar
I would think 195 or so. Try swapping the fan relay with the horn relay, could be that relay is bad. Does your instrument cluster have a temp guage or just a light?
Old Nov 12, 2021 | 4:01 PM
rocky10954's Avatar
hi Kevin , it has a gauge, please explain to swap relays ,
i am new to new chevys, i am a old solid axle corvette man
these i can fix
many thanks, rocky
Old Nov 13, 2021 | 7:04 AM
kevinkpk's Avatar
these i can fix
many thanks, rocky
Under the hood is a fuse box. There should be relays and the lid to the fuse box will tell you what fuse/relay is for what. Remove the fan relay, and plug the horn relay in that socket. Also check the fan fuse.
Old Nov 13, 2021 | 7:07 AM
kevinkpk's Avatar
Also check the fan fuse. The other thing depending on your skill level is to jumper the socket pins under the fan relay, that is a direct circuit from the fuse to the fan motor.
Old Nov 24, 2021 | 6:51 PM
rocky10954's Avatar
hi guys , still having problems sorting out my non working fans,
I removed the hook up on the sensor on the intake manifold,
both fans came on very strong.
I then checked fuses [ marked fan cont. 2&3, fan cont1 ]
and exchanged one for the other, no change still no fans.
also no breaks in the fuses, both appear good and not blown.
I then exchanged the fan cont. 1 with fan cont. 2 , no fans
and then test both relays in the crank relay position on the upper fuse box
all relays tested as much as my limited know how could go, I am lost
cam someone pleas assist me on how and what to check next ??
please post
happy holiday. many thanks, rocky
