2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2016 Impala- Audio off
Old Feb 8, 2017 | 12:11 PM
scirocco's Avatar
Default 2016 Impala- Audio off
No audio at all, no open door chime, no key in ignition reminder, no onstar, no turn signal click, no radio, cant change from fm to am or xm, can't direct tune radio. Have tried removing fuses, restarting car, disconnecting battery but driver information center still says "Audio:Off" Anything i can do short of taking it to the dealer? it's still under warranty so they should take care of it.
Old Feb 21, 2017 | 7:43 AM
Official GM Rep
Hi there scirocco,
We regret to hear about this audio concern you're experiencing with your Impala, and we'd be happy to look into this further for you on our end. If that is of interest, please send us a private message at your earliest convenience.
We look forward to hearing from you,
Chelsea D.
Chevrolet Customer Care
Old Feb 21, 2017 | 9:54 AM
You say you removed the fuses. Did you check them to see if they were all good before putting them back in? Sounds like a power loss to the audio system which could be a blown fuse. This would be the first thing to check!
Old Feb 21, 2017 | 12:44 PM
Gravydog316's Avatar
i found 2 possible fixes:
1)
Leave your engine
off.
Open your door for 3-5mins.
close your door for 3-5mins.
Turn the engine on.
2)
pull the radio fuse #4, which is
on the drivers side, behind the storage bin:
Old Aug 24, 2017 | 6:22 PM
Dahir Mohamed's Avatar
Hi scirocco please let me know what tgey said it was because I am having the same issue.
Old Jun 9, 2018 | 8:39 PM
Rac Noleium's Avatar
hey! I would like to know the solution for this problem because I'm having the same issue with my car, thanks
Old Jun 9, 2018 | 8:41 PM
hey Dahir did you ever find a solution to that issue because I'm having the same issue.
Old Jun 12, 2018 | 1:25 PM
cmacumber's Avatar
I am having this problem, too. Were you able to find the problem?
Old Jun 25, 2018 | 4:25 PM
i posted the solutions months ago
Old Aug 9, 2018 | 1:59 AM
sanogo's Avatar
Default Impala 2014 - Audio off
Hi, Please can you repost the solution. I have the same problem with my car
