2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Befuddled!!
Old Feb 25, 2022 | 12:39 PM
xjmathews's Avatar
Default Befuddled!!
I have a 2004 Impala non-supercharged 3.8 that just hit 120K. My wife came home from work and parked it in the garage and the next morning it wouldn't start. It turns over but won't start, even with spraying starting fluid into the intake. I've already replaced the plugs, wires, coil packs, injectors, and crank position sensor to no avail! There is pressure on the fuel rail and the lights, radio, turn signals, horn, door locks and windows all work perfectly...but for reason I'm getting no ignition! Anyone else had this problem? What else is there to change? Any help would be greatly appreciated!!!
Old Feb 25, 2022 | 2:16 PM
Welcome from Florida. Is the check engine light on? If you have access to a scanner, have the codes read and this will lead you in the right direction.
Old Feb 25, 2022 | 5:24 PM
xjmathews's Avatar
Yes, oldchevy, the check engine light is on, but the only code that shows up is a misfire on cylinder 6. And btw, I have also changed the O2 sensors as well!
Springer
1988 - 1998 (GMT400)
Jan 30, 2019 10:05 AM
Lukas Johnson
Oct 4, 2018 1:12 PM
DementedMind
Mar 15, 2016 10:07 AM
bigj-dog
Aug 28, 2014 9:17 AM
Jason1Tennant
Dec 23, 2013 10:13 PM
