2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Headlight
Old May 20, 2019 | 7:08 PM
Javier Nieves's Avatar
Default Headlight
Can this be fix? Picture below
Sealed leak
Old May 20, 2019 | 9:40 PM
OEDRO's Avatar
Former Sponsor
There are several reasons may cause the fogging, for example, the headlight assembly is cracked, the dust cover is not covered, the dust cover is broken, the sealant is aged, and so on.
The fog will seriously affect the lighting. You can go to a local refit shop or repair shop to solve the problem or change new light.
If the headlights enter the water, the light will accelerate the aging of the headlight assembly, and if it is short-circuited, the vehicle will spontaneously ignite.
You cannot underestimate this problem.
New headligts:
https://www.yitamotor.com/products/headlights-for-06-07-monte-carlo-2009-2013-chevy-impala
Old May 21, 2019 | 7:21 AM
Remove the assembly and give it a close inspection.If the seal looks cracked or damaged you can clean it or remove it and reseal with a good silicone seal. It has worked for me and if you are a little lucky it will work for you.
Old May 21, 2021 | 4:46 AM
Carpart oedro's Avatar
To thank our old customers, we provide 12% off for all products at yitamotor.com.
12% off code: YITA12
Wish you have a nice day!
Old May 21, 2021 | 5:32 PM
Impala-Blue-2.'s Avatar
Not True, If it shorts out it will blow a Fuse, Fuseable Link or Circuit Breaker, it will not start the car on fire. I don't know where people come up with this stuff.
mfvandermolen
Sep 20, 2020 11:09 AM
nickcronan
Mar 9, 2020 12:13 PM
blueinterceptor
Feb 21, 2015 11:51 AM
gotstylez
Dec 16, 2009 9:02 PM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 24, 2008 6:35 PM
